Is it flanged on one side and plain on the other side?
Do you confirm you buy a piece of pipe with pre-welded flanges as it would be one component?
If yes, I stay on my position. It has to be a FTUB. Easy.
yep it is like that only then ftub is the component to be used what about BOQ as it is going to appear as FTUB in Isometric.; How do i take care of that?
To me, It doesn't matter.
It is not "bulk" material. It is a proper component.
If this is a major problem for your customer, you could think about changing the material list group heading from "FITTINGS" to something like "FITTINGS & SPECIAL PIPES" ;-)
yeah you are right then bolting from 14"-48" need to be set the bltref and how do we set the bolting because its not flange its pipe with flanged ends .The coco table needs to be updated as pl-pl or fl how do we set it.
It is a component. It is a sort of very-very-long welding-neck flange :-))
Simple and easy.
Set the BLTREF.
COCO on the P-Point on the flanged side will be something like FBB
Now i think I have given you enough tips.....it is time to stop for me......otherwise Aveva will send you the invoice for my consultancy... ;-)
Simple and easy.
Set the BLTREF.
