• Hi..
    I was working in design module without any problem. But suddenly it is showing FAILED TO OPEN MDB / xxx - SWITCH TO MONITOR for opening design module.
    Pls advise why this problem is occurring. And how to fix it.
    Thanks I'm advance.
    Regards
    Anil Kumar
  • Hi in recent I have faced this same issue. I tried to resolve by login in admin module and modify particular MDB and removed some db files which not availble in presnt project. I think this is one of the method to solve issue. But there is still needs to find the source of Missing db files and properly needs to copy foreign db to particular project.
    Any one guide me about my understaing, is it correct for this issue.
  • when you are in monitor, in command line, write :
    alph log /c:\temp\errorlog.txt over
    design
    when back in monitor, you got in your c:\temp folder the file errorlog.txt
    edit it and you will have some information : name of db ...
    hth
  • [QUOTE=trinhnd;108661]Hi all,
    I have a project source which is copied from Client, they ask to do a modification job and require update to 3D model.
    I can access to Admin module with user SYSTEM/XXXXXX and able to change anything, but when trying access to Design module is still get Error : "FAILED TO OPEN MDB / xxx - SWITCH TO MONITOR".
    Only one way to open Design is check in "READ ONLY" check box, then unable to edit anything in Design module.
    I have tried any way but it's still not fixed.
    Anyone know what happen & how to fix it ?
    Thanks any attention !
    Please, check your MDB, maybe they have some DB's with Acess Mode, maybe "update", they can private you to open same MDB in multiple instances.
    [QUOTE=Anil;112269]Hi..
    Thanks I'm advance.
    Regards
    Anil Kumar
    Anil, please check the previous reply i've made for trinhnd
  • Same thing happen to me.. Some DB is Missing from MDB or change been made by mistake..
  • Once I had this problem.
    This was because the MDB I was trying to enter had one foreign DB from an old project... I just wanted to hide that old annoing project from the project select screen and i change the EVARS, removing the line that calls the old project
    then, I just couldn't acces that MDB again until I realize of my mistake.
    I hope my weeks of torture helps you :)
    take care
