• Dear Experts
    I am trying to Create a Bolt spec and wanted to bolt details in Isometric extraction.
    I created a Bolt Spec and given a Bolt spec reference to Pipe Spec, but still I can't see bolt details while extracting the ISO.
    Here I followed the steps to create Bolt Details as below:
    Just give me feed back where I went wrong
    [COLOR=#0000ff]Step Wise:
    1: NEW BLTA / NSB.BOLTS
    2. NEW BLIS / NSB.#300.STUD
    3. NEW SBOL / NSB.SBDD
      Edit the Attributes as below mentioned
      Nstdblength Nulref -Nstdblength /M12
      Bitems unset - Bitems NUT WASH WASH NUT
      Btlength unset -Bitlength 20 2 2 20
    4. NEW LTAB /NSB.LTAB
    5. NEW DTAB /NSB.M12
      Attributes to be edited as below
      Btlength unset  - Blength (50 60 70 80 90 100)
    6. Go to SBOL, and edit the attribute as below mentioned
      Nstdblength nulref - NSB.M12
    7. Go to Category "Flange"
      create new BTSE
      Here Bthickness parameter should be updated as, Falnge thickness Param , which we defined during Flange cata
    8. Under BTSE, create BLTP, name as NSB.1
      NUMBER 0  - Number 1
      Bdiameter - Bdiameter 12
      Btype unset - Btype BOLT
      Then stay at BLTP . 1
      Create N No. of BLTP as per Bolt No.
    9. Then go to FLANGE (Scom), need to Set Blrfarray as same BTSE name
    10. bolt spec to be generated.
    11. Go to Pipe Spec, select one,
      Attributes to be edited as below:
      BLTMETHOD - NEW
      BSPEC - /NSB.#300.STUD.BOLT.SPEC (bolt spec name)[/COLOR]
  • First this is a NEW method but not OLD as in topic name.
    Then not seeing your bolting spec it is hard to say what is wrong
  • Above steps were during training session I made. And this training held in 2006. and I was just using existing cats.
    Just for a change I was trying to do my own, I could not.
    Any experts Can help me
  • Hi Ruav,
    Thanks Men, I got the solution, while spec creation, I given a wrong name for BLTREF.
    If somebody is new for Bolting they can still follow the above steps.
