Dear Experts,
Requirement to copy pipe specification from one db to another db with same references within same projects.
Can you let me know what commands/any method available to do so .
Thanks and Regards,
Junaid Hussain
Dear Experts,
Thanks and Regards,
Junaid Hussain
Firstly why its needed with sameref??
Each dB got its own reference series this cant be done when its in other DB with sameref but its possible to have sufixed/prefixed name for SPCO then change in design if i understand you requirement correctly
The design team already started modelling using the spec which is in current db...
we want to shift the spec to different db so that references in model should not disturb....
current spec location is in wrong db...
we want to copy the spec to proper db...
then you can reconfigure
Can you please provide the commands to reconfigure this particular spec instead of whole db...
