Method for creatin symbol in pdms though Autocad
  • Symbols Creation
    Before attempting to create a symbol in PDMS the user should know the hierarchy where to create this symbols so that it can be used to create ‘SLAB’ in the views.
    All the symbols for BHEL are stored in the following hierarchy
     DEPT  -    / MASTER-LIBRARIES
     LIB      -    /BHEL-LIB
     SYLB  -    /BHEL-GEN
     SYTM-   /XXX  (The name of the Symbolic Template)
    To create a new SYLB first create backing sheet for the symbol library. The sheet limits has to be checked for its size before it is created. It is recommended to create the symbols using the soft copy.
    The procedure to create the symbol is:
    Steps for creating Symbol
    Step 1:  Open the drawing in AutoCAD.
    Step 2:         At command line give the command ‘DDATTDEF’.
    Step 3:         A form will appear, toggle on the invisible button.
    Step 4:         Give the Tag as ‘PDMS_NAME’.
    Step 5: Select the pick option and pick the required point for the base point of symbol and        Press  ‘OK’.
    Step 6.:          The PDMS_NAME appears on the screen at the picked up point.
    Step 7: Now previous point. Create a block with some name and select insertion base point same as
    Step 8:          Select the symbol along with the PDMS_NAME label.
    Step 9: Insert the block while inserting the block you will be prompted for various details, ignore all except PDMS_NAME. At PDMS_NAME, give the name of the SYTM. This will be your name of the symbol.
    Step 10:            Appload the lisp files from C:\cadcentre\pdms11.2\autodraftR13\*.Lsp.`
    Step 11: At command line type ‘PDMS_SYMBOLS’.
    Step 12: Give the Draft Symbol Library name.
    Step 13: Give the draft command file name as C: \temp\some relevant file name.
    Step 14: Close the AutoCAD drawing.
    Step 15: Login to PDMS Draft Module.
    Step 16: Give the following command at command line ‘Tol 0.01’(this sets the precision to 0.01).
    Step 17: $m/c:\temp\ the file name you have given.
    The symbol library is created in your respective library (SYLB).
    Note:  The size of the backing sheet for the symbol library (SYLB) and the backing sheet should be same If    you want to position the SYTM using the cursor in your symbolic library, be at the sytm and give the following command.
            U should run this macro in draft administrator symbol library, u should created symbol library with same name  in draft before run this macro  .
    In auto cad
    Command: ddattdef
    And make a block with same name ,
    Command: pdms_sysbols
    Inch/
  • this is a very useful post, I'm surprised more people have not noticed this one.
  • Step 5: Select the pick option and pick the required point for the base point of symbol and Press ‘OK’.
    where this option is available in PDMS
  • [QUOTE=deva;58808]Step 5: Select the pick option and pick the required point for the base point of symbol and Press ‘OK’.
    no-no, this step for autocad only
  • hi guys am working on skey generation as per above procedure
    but am getting output file as follows
    $* Drawing: SURYA.dwg Date: 21 November  2011 15:54
    ONERROR CONTINUE
    CALLDRE ALOADINIT Mm
    LABEL /SYTM2
    OWNER
    $S+
    CALLDRE ALOADTIDY OK
    RETURN
    Am unable to understand what is the attribute definition and blocking commands in auto cad.please explain me what is necessity of doing those 2 commands in auto cad.
  • hi guys i got it thanks a lot,but am unable to create a arc in isotm,what should i do here
  • You need to create many smaller straight lines....
