Draft Module
batch plot
5 subscribers
batch plot
sivaraman
over 15 years ago
Sri
over 11 years ago
i have trid graphics_dxf and default_dxf
but not succeded ...
Corrado Galluzzi
over 11 years ago
I do not have enough info to help you.
Why don't you contact
http://www.aveva.com/en/Contact/Worldwide_Offices/AP/Mumbai.aspx
Sri
over 11 years ago
Yeah I got it with an error ?Directory not found for file
Then how to define directory now ?
Sri
over 11 years ago
Thanks Carrodo,Surely i will cantact them.
Sri
over 11 years ago
hello i found the answer at
http://52.178.132.139/showthread.php?t=11422
Kiran B. Bachhav
over 11 years ago
i have same problem while running macro it's showing
(81,2) LI application already loaded
Please help
its urgent
thanks
Sri
over 11 years ago
I believe,You have not given proper path
try
PLOT SHEET DXF /UR PATH \UR FILENAM.FILE EXTESNSION
Kiran B. Bachhav
over 11 years ago
but i want it in batch plot
Sri
over 11 years ago
Example:-/Aveva-PDMS-SHEET/022/2047-AREA/S1 PLOT SHEET DXF /C:\surya\Supports\Aveva-PDMS-SHEET52047-001-C01.DXF
be on your drawing /Aveva-PDMS-SHEET/022/2047-AREA/S1
Kiran B. Bachhav
over 11 years ago
thanks
but I have created one sheet in one drawing
so like this I have 18 dwg each contain only one sheet
then how i can collect all the sheets at a time & plot in batch in dxf & pdf
thanks in advance
