• collect list or repot it in notepad..or excel..
  • Hi,
    i want same but for pdf then how i can write the code.
  • sheet print to pdf. just put it into do loop circle with sheet collection
    if (!!CE.Type NEQ 'SHEE') then
      !!Alert.Message('Goto Sheet'
        return
    endif
    !OF2FN = 'c:temp\Drawings\2D\'
    !OF2 = object file(!OF2FN)
    if (!OF2.Exists().Not()) then
      SYSCOM 'MKDIR $!OF2'
    endif
    !fileName = !OF2FN + !!CE.Name.Replace('/','_').Replace('\','_') + '.pdf'
    PLOT CE PDF/$!fileName 'Text' OVER
    !needOpen = !!Alert.Question('Open file? If NO, folder will be open')
    if (!needOpen EQ 'YES') then
      SYSCOM '$!fileName &'
    elseif (!needOpen EQ 'NO') then
      SYSCOM 'EXPLORER $!OF2FN &'
    else
    endif
  • plot /SHEETNAM  pdf /pATH ' MTNL .022, COL BW SHEET'A3 OVER
    BUT AM NOT GETING WHITE LINES FROM BACKING SHEET
    EVEN I CHANGED COL BW TO GREYSCALE/STANDARDS ETC
    ANYBODY CAN HELP ME HERE?
  • this is the error while click on the button
    (2,779)   Method .PLOT1() not found
    In line 1 of Command/Form Callback Command
    !THIS.plot1()
    below is my macro can anybody tell me what is wrong in that or correct it.
    thanks
    button   .REG          'REGISTRY:'          CALL |!THIS.REGI()| para .Toggle  At Xmax .reg + 1   width 30 height 1
    list     .List1       ''                                 at xmin.REG   ymax.REG +.2   MULTIPLE      width  40  height 10
    button   .PL         'PLOT'          CALL |!THIS.plot1()|    at xmin.List1 +1 ymax+.2
    DEFINE METHOD .REGI()
    !REGI = REGI
    HANDLE(2,111)
    !!alert.error('You must be on or below a REGI')
    ENDHANDLE
    VAR !DRWGCOLL COLL ALL SHEE FOR $!REGI.name
    VAR !List1Array EVAL NAME OF SHEE FOR ALL FROM !DRWGCOLL
    !THIS.TOGGLE.VAL = '$!REGI.NAME'
    !THIS.LIST1.dtext = !List1array
    endmethod
    DEFINE METHOD .plot1()
    !SelectionList = !This.List1.Val
    !SelectionCount = !SelectionList.Size()
    Do !x from 1 to !SelectionCount
       !Drawing = !This.List1.Dtext[$!SelectionList[$!x]]
       VAR !FirstPart  (|C:\TEMP\PLOTS\|)
       VAR !SecondPart (|.S1.plt|)
       !DrawingName = !Drawing.Before('/S1').AFTER('/').REPLACE('/','-')
       !NewText = !FirstPart + !DrawingName
       $!Drawing
       Var !ViewColl coll all view for CE
       !ViewCount = !ViewColl.Size()
       Do !a From 1 to !ViewCount
           $!ViewColl[$!a]
           !lframe = lframe
           if(!lframe eq TRUE) THEN
           lframe off
           HANDLE ANY
           ENDHANDLE
           endif
       enddo
    $P $!Drawing ------ Sent To Printer!!
    PLOT $!Drawing /$!NewText CUTM OFF over
    syscom |%CADC_PLOT_DIR%\7S-PRT1.bat  $!NewText|
    syscom |del $!NewText|
    enddo
    endmethod
  • [COLOR=#333333]Where is Setup form commands?[/COLOR]
    +Where is 'exit' command---->end of gadget declaration
  • http://52.178.132.139/showthread.php?t=17393&p=97053#post97053
