Draft Module
Hiding components
5 subscribers
Hiding components
Russen Harold Cordovan
over 14 years ago
over 14 years ago
Hello world,
Is there an easier way to hide components in draft?We are trying to remove some eg. elbows near the end of a cutting plane and add some pipe cut symbol.
Thanks in advance.
abdul munir
over 14 years ago
did you try to remove item from drawlist ?
over 14 years ago
i think it will work if you will use drawlist to remove the component unless you will remove the whole branch.. tried it already
over 14 years ago
oopps...i forgot *NOT WORK if you will use drawlist..
Corrado Galluzzi
over 14 years ago
Try using the "Omit fractional pipe components..." Section Mode option when creating a view.....
Venkata Siva Kumar Manthena
over 14 years ago
Neil Dryden
over 14 years ago
Add a separate cutting plane that only effects the pipe..
Not pretty but it'll work..
over 14 years ago
hello neild,
Thanks for sharing your idea.
But using this style will make updating slower. Users also got so several components to cut/remove from view.
over 14 years ago
@corrado Users want to choose certain components to remove or cut in the view.. so this setting is not applicable..hehe..
tanx
Corrado Galluzzi
over 14 years ago
[QUOTE=alinofeire;52500]@corrado Users want to choose certain components to remove or cut in the view.. so this setting is not applicable..hehe..
tanx
Ok. I understand now. I thought they wanted to remove components cutted by section planes.......
