Error getting while opening draft module
    # DRAFT SYSTEM DEFAULT FILE
    # This file is compatible with ALL module versions
    # Draft System Defaults File : /%PDMSDFLTS%/DRA-GEN-SYSTEM
    # Created By                 : SYSTEM
    # Date                       : 26 Mar 2013 12:34
    # Layer Purpose Definition
    PURPLIST NOT DRA-GEN-NOTLAY    DIM- NOT+ TEX- LAB- SYM-
    PURPLIST LAB DRA-GEN-LABLAY    DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST EDI DRA-EQUI-DIMLAY   DIM+ NOT- TEX+ LAB- SYM-
    PURPLIST DIM DRA-GEN-DIMLAY    DIM+ NOT- TEX+ LAB- SYM-
    PURPLIST TAG DRA-GEN-TAGLAY    DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST MAT DRA-GEN-MATLAY    DIM- NOT+ TEX+ LAB- SYM-
    PURPLIST ADA DRA-ADP-DIM1LAY   DIM+ NOT- TEX+ LAB- SYM-
    PURPLIST ADB DRA-ADP-DIM2LAY   DIM+ NOT- TEX+ LAB- SYM-
    PURPLIST ADC DRA-ADP-DIM3LAY   DIM+ NOT- TEX+ LAB- SYM-
    PURPLIST ADE DRA-ADP-EQUICLLAY DIM- NOT+ TEX+ LAB- SYM-
    PURPLIST ADL DRA-ADP-BRANINLAY DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST ADP DRA-ADP-PESYMBLAY DIM- NOT- TEX- LAB- SYM+
    PURPLIST ADS DRA-ADP-SCHEDLAY  DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST ADT DRA-ADP-TAGLAY    DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST HSM DRA-SUPP-HSMLAY   DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST STB DRA-SUPP-STBLAY   DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST SIB DRA-SUPP-SIBLAY   DIM- NOT- TEX+ LAB+ SYM-
    PURPLIST HAD DRA-SUPP-HADLAY   DIM+ NOT- TEX+ LAB- SYM-
    # Layer Creation Definition
    LAYCREATE USER_Equip_Dims EDI
    LAYCREATE USER_Dims  DIM
    LAYCREATE USER_Labs  LAB
    LAYCREATE USER_Notes NOT
    LAYCREATE USER_Tags  TAG
    # Layer Purpose Defaults
    LAYPURP LAB  LAB TAG ADL ADP ADE ADS ADT
    LAYPURP DIM  EDI DIM ADA ADB ADC
    LAYPURP DRA  NOT ADE
    LAYPURP GDP  DIM LAB TAG NOT ADA ADB ADC ADE ADL ADP ADS ADT
    LAYPURP USR1 DIM LAB
    LAYPURP USR2 DIM LAB
    LAYPURP USR3 DIM LAB
    LAYPURP USR4 DIM LAB
    LAYPURP USR5 DIM LAB
    # Element Name Delimiters
    STYLDEL  / # style name delimiter
    LALBDEL  / # label library name delimiter
    DLLBDEL  / # Drawlist library name delimiter
    # Master Library References
    SYMB     /DRA/MAS/SYMBOLS/GEN  # Symbol library area (LIBY)
    SLAB     /DRA/MAS/LABELS/GEN  # Symbolic label library area (LIBY)
    PESYMB   /DRA/MAS/LABELS/GEN/PIPE/END  # Pipe End Symbol Template (SYTM)
    BSRF     /DRA/MAS/BACKS/MET # backing sheet library (SHLB)
    TAGTMPLT /DRA/MAS/LABELS/TAG # Auto tagging template library area (LIBY)
    PIPLAB   /DRA/MAS/LABELS/GEN/USERDEF # ADP pipe label prefix
    # Project Library References
    DLLB     /DRA/PRJ/DRAWLISTS  # drawlist library (LIBY)
    OSRF     /DRA/PRJ/OVERS/MET  # Overlay sheet library (SHLB)
    RRSF     /DRA/PRJ/REPR/GEN # representation rules (RPLB)
    LRUL     /DRA/PRJ/STYL/LOCAL # local styles (RPLB)
    TAGRULE  /DRA/PRJ/AUTOTAG # Auto tagging rule library area (LIBY)
    CLRF     /DRA/PRJ/CIRCULATION/GEN  # circ list library (CLLB)
    TMPLT    /DRA/PRJ/TMP # DRWG Template registry prefix
    TMPLTDEF /DRA/PRJ/TMP/PIPING/A0 # Default DRWG or SHEE Template
    HRSF     /DRA/PRJ/HRUL/GEN # Hatching Rep rules (RPLB)
    HRUL     /DRA/PRJ/HSTYL/LOCAL # local hatching styles (RPLB)
    CRSF     /DRA/PRJ/CHANGE/RULESET # Change Rep rules (RPLB)
    # Sheet sizes and option gadget descriptions
    SHEETSIZE 1189mm 841mm A0
    SHEETSIZE 841mm 594mm A1
    SHEETSIZE 594mm 420mm A2
    SHEETSIZE 420mm 297mm A3
    SHEETSIZE 297mm 210mm A4
    SHEETSIZE 297mm 420mm P3
    SHEETSIZE 210mm 297mm P4
    # Name Convention
    # Mandatory Names
    NAMECONVMAN DEPT DEPT
    NAMECONVMAN REGI REGI
    NAMECONVMAN DRWG DR
    NAMECONVMAN SHEE S
    NAMECONVMAN VIEW V
    # Optional Names
    NAMECONVOPT NOTE SN ON
    NAMECONVOPT VNOT LN OFF
    NAMECONVOPT RRUL LR ON
    NAMECONVOPT VSEC VS ON
    #End of defaults file
  • Check you backing sheet size which you are using as ref.
  • is it possible for hiding line 11 for a mean while with --
    can you please check with this option.
  • Deva,
    Sorry i dint get you. Could you please explain.
  • [QUOTE=sherly;102289]Deva,
    In your DRA-GEN-SYSTEM Can you hide Line 11 with -- and check.
  • [QUOTE=sherly;102345]Still have the same issue.
    Please advice
    In the case, why don't you contact your local Aveva Office?
  • Are you sure you are pointing to the correct DRA-GEN-SYSTEM file?
    Check PDMSDFLTS variable...
  • Dear Corrado,
    I contacted local office and tried. But no solutions yet.
