Hi,
I got a very strange issue, Global communication was done. I tried to renew the transaction DB. But every time I expunged all users, the admin module frezen. So I have to power off and power on.( Restart, or task manager can not kill that Admin session ). After 2 times power off and power on (it's painful) , I can access Admin module again. No only expunge, some other action in admin module would cause frozen too. Then I found I have a garbage user - my name added there. If I shutdown 3 times, then 3 of my name there, which cannot expunged. Because this, I can not renew transaction DB. it said, there were users still in system. How can I release the lock of transaction DB? How can I expunge these ghost users? How to fix this to make Admin module works again. Please help. Thanks in advance.
We use PDMS12Sp6.36 on windows xp workstation.
To rename transaction db, you should to expunge all users from the project but don't forget it lock the project first, also check if daemon is open and stop it, after that you can rename transaction db then you start again your daemon and a fresh transaction db will be created.
