Global Module Global Cannot Communicate
  • Replies 3 replies
  • Views 65 views
Jermaine Nuevo
Jermaine Nuevo over 6 years ago
  • Jermaine Nuevo
    There is a problem in communications between sat and hub as below:
    "There are no more endpoints available from the endpoint mapper"
    Daeonat HUB and SAT are working and run successfully for themselves. But when I try to "Test Communication" in ADMIN Module, it gives the above error.
    Pls help
  • Venkata Rao Peta
    This is a small solution in global, if every is fine.
    Stop the daemon at hub and satellite. Delete transaction databases.
    Start Daemon creates new transaction databases.
    After this check the communication.
    Long back this solution worked for me.
  • me_hungry
    me_hungry over 6 years ago
    You need to modify (but make file backup) host file to direct domain traffic to specific external IP:
    C:\Windows\System32\drivers\etc
    File Sample content:
    [COLOR=#008000]#Local IP External IP[/COLOR]
    127.0.0.1 157.240.18.35
    Also make sure that you can ping your external location with CMD.
    There are some configuring Global documentation, that you can ask from local support.
