Paragon Module 4 weld mitre 90 deg catalogue
  • Replies 7 replies
  • Subscribers 8 subscribers
  • Views 62 views
anindya ganguly
anindya ganguly over 7 years ago
    Corrado Galluzzi over 7 years ago
    You can have as many cuts as you like using variable cuts-variable angle-variable radius bends.
    Just change NCUTS attribute at BEND level once in Design module.
    Here below the new CATE belonging to the  /NEW-MITRE-BENDS Section of Aveva supplied ACP project
    /00BU0WN  180 Degree Bend
    /00BV0W0  Variable Radius Variable Angle Bends
    /00BV0W1  Variable Radius Variable Angle 1 cut Mitre Bends
    /00BV0W2  Variable Radius Variable Angle 2 cut Mitre Bends
    /00BV0W3  Variable Radius Variable Angle 3 cut Mitre Bends
    /00BV0W4  Variable Radius Variable Angle 4 Cut Mitre Bends
    /00BV0W5  Variable Radius Variable Angle 5 cut Mitre Bends
    /00BV0W6  Variable Radius Variable Angle 6 cut Mitre Bends
    /00BV0WN  Variable Radius Variable Angle Variable cut Mitre Bends
  • anindya ganguly
    can i find handy a catalogue for 90 degree and 4 degree mitre there is no refrence available in sample project can you please share a sample catalouge
  • anindya ganguly
    are there catalogues for 5 piece mitre 90 degree and 45 degree mitre 3 weld in smaple project , I am unable to find them .Can you share the same or is anyone having such catalogues handy
  • anindya ganguly
    thanks corrado
  • MIKAEL BEZERRA COTIAS DOS SANTOS
    MIKAEL BEZERRA COTIAS DOS SANTOS over 1 year ago in reply to Corrado Galluzzi
    Hi, Those categories are without geometry set on the ACP project...
    Does anyone have it full??
    Corrado Galluzzi over 1 year ago in reply to MIKAEL BEZERRA COTIAS DOS SANTOS
    That's the way it works.
    They are "special" components with no geometry set.
    Interesting, I don't recall ever using mitre bend on E3D...But, E3D really draw them
    I am certainly going to investigate how this work.
    Thanks
