Specon Module Creat Assemblies PDMS 12
  • Replies 30 replies
  • Subscribers 3 subscribers
  • Views 134 views
Mathieu Bottolier
Mathieu Bottolier over 13 years ago
    Corrado Galluzzi over 13 years ago
    Which kind of assembies are you talking about?
    I mean...in which SAM MDB and what is the name of the APPLDW you are looking at?
  • Mathieu Bottolier
    Hi,
    Is anyone can tell me how to create assemblies in PDMS 12, after few minutes to
    understand, I found a example in SAMPLE Project, where Assemblies are made of
    Design Parameters Template, but where is the link between the Piping Spec and
    the Template?
    Thx
    Math
  • Mathieu Bottolier
    Hi Corrado,
    I want to create a assembly for a basket for strainer, which should come with a tee, a flange w/ gasket & blind flange and a basket. So I was looking for
    the flanged-tee in SAMPLE Project.
    When you are going to buy a T type strainer, doesn't is come from the supplier with the basket, the tee, the gasket and the blind flange as one piece?
    Can't you do it as one component in Paragon?
    Anyway, you just need to model it once in Design, then you create the necessary hierarchy starting from APPLDW and by pressing the Copy Design button you select the components you need to be part of the assembly.
    For further help you can read C:\AVEVA\Plant\PDMS12.0.SP6\Manuals\Docs\Pipework Design User Guide.pdf Chapter 12 Piping Assemblies
    Hopr this can help
    I tried to pull it down into design.
    What do you mean?
    Which kind of command are you using to create an assembly???
  • Parag S Newe
    Parag S Newe over 12 years ago
  • Parag S Newe
    in component creation  form we can see Assemblies.
    This VENT assembly is not appear in assembly option.
    You mean the form that comes out from Create-->Components... or the new 12 one that you open by clicking on the "Show pipe component creation form" icon?
    You will be able to see your assemblies only with the new 12 form....
  • Parag S Newe
    yes .. i mean
    when i open ''Show pipe component creation form'' , i can see that assembly.
