Specon Module Creat Assemblies PDMS 12
  • Replies 30 replies
  • Subscribers 3 subscribers
  • Views 151 views
Mathieu Bottolier
Mathieu Bottolier over 13 years ago
  • delo
    delo over 12 years ago
    Hi,
    Some issues I have with piping assembly (drain assembly):
    1. Using the aveva sample project, I tried using the distance command on the olet in the header pipe but it doesn't work. Tried it on the branch pipe and it works. The distance command would be very handy in setting the distance of the olet from a fitting weld(ie. elbo, tee etc.)
    2. It seems that an assembly consisting of an olet (tee is fine) would only work on the sample project (aveva piping specs) but not on our company specs.  Apparently the problem was in the connection, "incompatible connection types". In aveva sample project, elbow and olet connections have both BWD while on our company specs, the elbow connection is BWD and olet is OLT (p1 & p2). Is there a work around on this? Can we use force connect the olet  to the previous component then set the distance? We can't change our company specs as there's another reason why it's done like that.
    Thanks.
  • Steven Convens
    Steven Convens over 12 years ago
    [QUOTE=corrado;75509]I am sorry sconvens....
    I thought it would have been straightforward....but it is not! :-(
    I will meditate about that.....and if I will find a solution I will come back to you....
    Had this investigated from my side by Aveva, this is a know issue, and is now logged for Enhancement (could not get it escalated to a bug)
  • Steven Convens
    Anybody else interested in this fuctionality, please log a ticket with you local aveva support, you can copy below. The more customers requested the more it will likely get "enhanced" :-)
    Dear Aveva Support,
    Is there a way to "FORCE" the Tee Piece in such assemblies, ie default it to an e.g YYmmx20mm tee-Piece. In other words users are not given the option to select the Tee Piece from the Catalog and hence make selection errors ?
    One  can read C:\AVEVA\Plant\PDMS12.0.SP6\Manuals\Docs\Pipework Design User Guide.pdf Chapter 12.3.5 Piping Assembly Component Rules. You can create "Selection Rules". I.e.g. SEL WITH PBOR3 20
    However please advise how this would work as below does not seem to do the trick for us
    Steven
    Thanks for the update...
  • ZAPPELLA
    ZAPPELLA over 11 years ago
    [COLOR=#333333]hi i create an assemblie for use in tool pipe splitting (simply a weld)[/COLOR]
    [COLOR=#333333]i copy [/COLOR]/flangeset-PIPE from aveva and change for my weld but i dont know how you do to place weld in the good spec when you split youre pipe.
    if you see the valid value of /flangeset-PIPE
    you have VALIDV ( '/A3B%WN%FALSE' )but i dont undertsand because the template flange gasket flange is build with spec A150
    what is syntaxe /xx%XX%XX
    Thanks
    Why don't you create your assembly from scratch?
    From the beginning.
    From zero.
    Instead of copying it from Aveva ones.
  • ZAPPELLA
    Scratch??
    What you mean
  • ZAPPELLA
    Yes i do this but rules(validv for valid value) not done..and i dont understand why
    Someone tell me that assembly with 12.0 and may be upper version..dont work with intelligent rules..
    So i think need to build same assembly for each spec but not afain try this way
  • Mohamed Naseh
    Mohamed Naseh over 8 years ago
    How can I force PDMS to choose specific STYP in assemblies?
