PDMS "Lessons Learned"
Installation & Upgrades
Problem running PDMS 11.6 in window 7
erlifie husin
over 15 years ago
Corrado Galluzzi
over 14 years ago
Which Flexman version have you installed? You need 5.2 if I am not wrong....
Marcel Prosch
over 14 years ago
because XPM is a virtual machine you cannot pull a license. I think the best way is to keep some older hardware and run 11.x from that one.
Charles Lu
over 14 years ago
I installed Flexman v4.1 on PDMS license server.
Maybe I'll upgrade Flexman's version to 5.2 and try again.
Thanks for your kindly & rapidly response.
Angello Padilla Maradiegue
over 14 years ago
Has anyone installed PDMS W7 12.0 in 64-bit?;
Is possible only with the installer DVD?
Cody Austin
over 14 years ago
I have it installed on my 64-bit Windows 7 machine. You just need the regular PDMS12.0SP6 DVD.
Ulf Geister
over 13 years ago
Try using VMware Player rather than XPM, works like a sharm with 11.5 and 11.6. Faster and more responsive.
Who needs old hardware when it works on the latest...
Ilgiz Kalimullin
over 13 years ago
[QUOTE=maysamab;42083]Dear all,
what is the xpm ?
Does pdms 11.5 is installed in windows 7?
Thanks
XPM is the XP mode. use google, Luke!
Paul Schmidmayr
over 13 years ago
Hi Erlifie,
I have the same problem! What have you done to overcome it ?!
thanks
Paul
Pactick Achterberg
over 13 years ago
Question for UlleG: Can you get a license from the license server using 11.6 running on VMware? Or, does the license have to be local?
Cody Austin
over 13 years ago
You can still get a license from a license server if you are running PDMS on VMWare. You just need to make sure they network is configured properly on your VM.
