PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Troubleshooting Plot problem
  • Replies 31 replies
  • Views 27 views
Plot problem
Javier Pozo
Javier Pozo over 18 years ago
  • Javier Pozo
  • Thomas Back
    Thomas Back over 18 years ago
    [QUOTE=bh0nst]Hello,
    i have some problems with lines LDASHED and DASHED in PlotViewer.
    These lines appear very separated.
    Somebody has these problems?
    bye.
    Actually we had the same problem when printing. It was especially annoying when small details needed to be shown with dashed lines.
    The solution I did was to create a user defined pen with very fine dashed lines.
    /Thomas
  • Javier Pozo
    Hello Tback,
    so, there is no solution for PlotView.
    I am going to try changing the definition of the lines.
    Thanks.
  • Thomas Back
    Actually this ha snothing to do with PlotView itself. The same problem also comes in our full-scale PDFs that we generate from PDMS.
    /Thomas
  • Thomas Back
    I can tomorrow post the pen definition I made if you like to try it out.
    /Thomas
  • Javier Pozo
    Thanks Thomas.
  • Thomas Back
    OK. Here are a few of the special pens I have set up for draft.
    -- Concrete glyph - middle of line
    LGLYPH 22 STA EXT 37 PARC 10 0 180 -10 0 180 10 0
    LGLYPH 22 ADD BRE PARC 25 -13 180 15 -13 180 25 -13
    LGLYPH 22 ADD BRE PARC 27 7 180 22 7 180 27 7
    LPICTURE 33 MODE 3 SIZE 2 REPEAT 4 GAP 50000
    SETPEN 213 COL 1 THIN SOLID LPICTURE 33 GLYPH 22
    LPICTURE 34 MODE 3 SIZE 1 REPEAT 2 GAP 50000
    SETPEN 214 COL 1 THIN SOLID LPICTURE 34 GLYPH 22
    -- Special fine dotted pen.
    LGLYPH 23 STA EXT 500 PLI -250 0 -150 0 BRE PLI 150 0 250 0
    LPICTURE 35 MODE 3 SIZE 4 REPEAT 4 GAP 50000
    SETPEN 172 COL 1 THIN SOLID LPICTURE 35 GLYPH 23
    Copy the above line definitions into the file %PDMSDFLTS%\DRA-GEN-LINDEF
    Next time you start draft you should be able to test the pens on any STRA element, by typing: NLPEN 172 (for the fine dotted line)
    I also made some special pens for the civil guys who wanted to show the concrete "hatching" on some drawings. This are the pens 213 and 214.
    Hope this helps you.
    /Thomas
  • Javier Pozo
  • Ivan Masnjak
    Ivan Masnjak over 16 years ago
    Let me just resurrect this thread for a moment, it's been very helpful for me in defining the LPATTERN of pen.
    We had a problem that dashed line turned up like solid line in PLOT, with very few breaks in between.
    My solution was to open DRA-GEN-LINDEF file and add the line
    LPATTERN 11 REP  2 DASH 1 GAP 1 DASH 1
    then I reffered to the LPATTERN in file DRA-PENS in following way:
    DEVPEN 171 Colour 2 DASH LTHICK 1 PLUS SCALE 1 LPATTERN 11
    PLOTPEN 171 Colour 2 DASH LTHICK 1 PLUS SCALE 1 LPATTERN 11
    and when I used PLOTPEN 171 for certain style I required, I got a very nice dashed line in PLOT.
    Hope this helps other people searching for this solution.
  • Anna Wanna
    Anna Wanna over 14 years ago
    Hello TBack
    How can I find proper path of DRA-GEN-LINDEF txt file ?  When I used Search command I got more than two doznes of files with this name.
    Regards
