dra-pens file was for setting up the 40 user defined pens only. From 131 to 170.
Now in PDMS 12 you can set up your user defined pens directly in the PADD (draft) database through STYLWL, LSTYTB and LINEST
I have tried on my pc and it works fine.
My version is: AVEVA PDMS Draft Mk12.0.SP6.12[7122] (WINDOWS-NT 5.2) (1 Feb 2011 : 20:37)
Please check the LWIDTH attribute of your LINEST
If you use the command line and type Q LWIDTH the result will not show you the decimals. So if it is set to 0.4 you will get 0. If 0.7 you will get 1.
So the best way is to use the menu. Query>Attributes
Ok thanks.
So....if I remember well.....using the User Interface you can select your own User Defined pens but they will be numbered from 1 to 40.
It means that Pen 1 corresponds to 131, 2 is 132, 3 is 133 and so on. Up to 170
If you use the command line you can use the "original" numbers. I.e. FFPEN 131
I am not sure pen 171 is user definable.
and when I used PLOTPEN 171 for certain style I required, I got a very nice dashed line in PLOT.
Hope this helps other people searching for this solution.
I'm gone resurrect it once more because I'm a little bit confused or I'm doing something wrong.
I've done all that you said but when I make a new STYL I can't choose 171 pen. Can you, or somebody else, help me with this one?
