PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Troubleshooting PDMS Project Version Upgrade
  • Replies 25 replies
  • Views 59 views
Srinivas K
Srinivas K over 12 years ago
  • Srinivas K
    Hi Friends,
    I would like to UPDATE PDMS Project Version 11.6 to PDMS Version 12.0 SP6.
    I read the manual, still I need a help to follow the step by Step, if anybody have macro please share ...
    Thanks & Regards
    Srinivas K
  • RAVI KUMAR
    RAVI KUMAR over 12 years ago
    configure project evars in 12.0 sp6 open project in sp6 and go to admin module the command ' UPGRADE PROJECT TO LATEST ' it will upgrade database
    Plenty of threads about this matter!
    Anyway you can read C:\AVEVA\Plant\PDMS12.0.SP6\Manuals\Docs\PDMS User Bulletin12.0.pdf Chapter 2.5 Upgrading from PDMS 11.
    In particular Chapter 2.5.2 Performing the upgrade process
    As far as I know the correct syntax is DBUP PROJECT TO LATEST.
    This is for upgrading from 12.0 to 12.1 as explained in the 12.1 PDMS User Bullettin
    This comes from the manual:
    If the project is not Global, the process is very simple[/U]. The upgrade is initiated by running the
    upgradeMac macro from the Monitor command window, either by typing:
    $m/C:\AVEVA\plant\PDMS12.0.SP6\pdmsui\dra\upgrade\upgradeMac
    or by dropping the upgradeMac macro on to the command pane.
    That's just a list of tasks that the upgrade process performs.
    You do not need to do anything apart (eventually) updating the spatial map.
    You can find answers to your questions in the PDMS 12 or 12.1 User Bullettin and in the Admin manuals.
    I would strongly recommend you to attend a PDMS Admin Training Course.
  • Admin
    Admin over 12 years ago
    thanks all of you      is it possible to downgrade the project?
  • Parag S Newe
    Parag S Newe over 12 years ago
    why you need to downgrade project?
    anyway , as per my knowledge, you cannot downgrade project,
    you can open project in lower version with FREE USER.
  • me_hungry
    me_hungry over 12 years ago
    For what need [COLOR=#333333]downgrade?[/COLOR]
    Haha)) When customer orders pdms project, not only [COLOR=#008000]rvm+att+isometric+reports[/COLOR] but also full project(dabacon bases). And he requires the same version as he use...
  • Admin
    There is no official procedure! It is only can be done by very experienced Administrator. Do you know about Datal output?
  • Admin
    there are no manuals for that.
    wouldn't it be strange if there were any? ;)
    this is just a workaround.
