Requirements Only works with 16 bit Windows (WIN3.11,WIN9x, WINMe). Do not use on NT-based machines.
Description This zip file is supplied to assist in the setting-up of Network Dynamic Data Exchange (DDE) on 16bit Windows machines. It contains a copy of the original 16bit 'ddeshare.exe' utility which provides a graphical interface for the establishment of DDE Shares on those systems. Without this utility, the user is required to manually edit both Windows INI files and registry entries. This utility does that for them.
