Draft Module Structure Sheets
  • Replies 22 replies
  • Subscribers 7 subscribers
  • Views 49 views
Structure Sheets
Angello Padilla Maradiegue
Angello Padilla Maradiegue over 15 years ago
  • Angello Padilla Maradiegue
  • Eric Callis
    Eric Callis over 15 years ago
    I was asked to do this years ago when we first started using PDMS in the office (95). It was a pain in the butt as you have to have a symbol for each SCTN type and different orientation. For examle, for an H shape you would need a profile along the axis (like a column in plan view), a profile flanges head on, and a profile web head on (assuming that you don't have to show any other bangs!).  Just remember that you can do a lot of axis flipping of symbols by using the xyscale with negative values and the Degree attribute.
    In my case I convinced them to accept line representation for plans and universal hidden for elevations/sections
  • Neil Dryden
    Neil Dryden over 15 years ago
    I've heard this has been achieved with geometry created in Cats & Specs...
    You have to take into account levels...what you want to see in draft isn't how you wish to see it in Design...
    Cheers
    Neil
  • Cody Austin
    Cody Austin over 15 years ago
    235252SCTNCutback..zip
  • sergey_b007
    sergey_b007 over 15 years ago
    Thanks codooaustin
  • Cody Austin
    Thanks codooaustin
    No problem.  The documentation is incomplete nor is it supported by AVEVA.
  • Eric Callis
    Nice. Who rolled that?
  • Cody Austin
    One of the rookie developers in the UK.
  • Travis Fincaryk
    Travis Fincaryk over 15 years ago
    I managed to achieve this without connecting steel, which will save time for our designers.
    I created a new LPICTURE in the DRA-GEN-LINDEF file:
    LPICTURE 21 MODE 6 SIZE 25 GAP 10
    Then the new PLOT and DEV pens:
    PLOTPEN 195 Colour 1 SOLID LTHICK 4 LPICTURE 21
    DEVPEN 195 Colour 5 SOLID LTHICK 4 LPICTURE 21
    Next in your STYLE change the MLNpen to 195
    You can model steel member-line to member-line, except when framing into a column they should be cut-back to the web or flange.
  • avwf_zplau
    avwf_zplau over 15 years ago
    Could this be the reason to leave out the "appuserdef.pmlobj' file described in the doc file?
