• Dear all
    I created all required catalogs for piping components that have ring type joint facing. I took the overall length for valves from face to face (Ring groove is included).
    My question is:
    What thickness of the ring gasket shall i use for these components? I think 0 mm is not the right choice.
    Note: for example I selected R47 gasket for my 6'' valves #2500 RTJ. In this case the gasket will disappear in the groove after bolting.
    shall i use the distance between flanges (4 mm for my example) as a gasket thickness?
    Thank in advance.
  • There is no space left after the gasket fitted into two flanges?
    You should substract gasket thickness (from standard) - groove width of flange 1 - groove width of flange 2
    this value is final gasket thickness.
  • Hello Deva
    For a 6'' flange (ASME B16.5) #2500 RTJ, we have a groove thickness of 12.7 mm and the overall length of the flange is 285.7 mm
    What i understand from your reply is:
    in the flange catalogue, the overall length is 273 mm
    in the gasket catalogue, the thickness is 25.4 mm
    Am i right Deva?
    thank you for your reply.
  • [QUOTE=Sargon;112612]Hello Deva
    Am i right Deva?
    Groove Width is provided for Flanges?
    From Gasket Overall thickness subtract these groove widths from two flanges.
    e.g. gasket thickness 25.4
    groove width for flange 1 is 7, groove width is for flange 2 is 7
    Now your gasket thickness is 25.4 - 7 - 7 = 25.4 - 14 = 11.4
  • [QUOTE=Sargon;112604]Dear all
    My question is:
    Thank in advance.
    To me it should be ZERO.
    Anyway, it depends on where you created P-Point 1 on the flange...
  • Hi Corrado
    Some standards tell you that some space is left after  bolting. For my example, 4mm is obtained from "PIPEDATA PRO" as a space  between two mating flanges. Regarding my P-Points, I used the same  philosophy in AVEVA catalogues (AAFWRJ??).
    Thank you my favorite member.
  • Some standards tell you that some space is left after bolting. For my example, 4mm is obtained from "PIPEDATA PRO" as a space between two mating flanges.
    So in this case the P1-P2 distance of the gasket should be 4mm
