エンタルピ関数の解説について
PIsystemで使用できるエンタルピの(以下の)関数の解説についてドキュメントは無いでしょうか?
StmEng_tsatp Saturation temperature as a function of pressure.
StmEng_hsatp Saturation enthalpy as a function of pressure.
StmEng_ssatp Saturation entropy as a function of pressure.
StmEng_vsatp Saturation vapor specific volume as a function of pressure.
StmEng_psatt Saturation pressure as a function of temperature.
StmEng_hsatt Saturation enthalpy as a function of temperature.
StmEng_ssatt Saturation entropy as a function of temperature.
StmEng_vsatt Saturation vapor specific volume as a function of temperature.
StmEng_vpt Vapor specific volume as a function of pressure and temperature. (For saturated and super heated steam.)
StmEng_vptl Water specific volume as a function of pressure and temperature.
StmEng_vph Vapor specific volume as a function of pressure and enthalpy. (For wet and dry steam.)
StmEng_vps Vapor specific volume as a function of pressure and entropy. (For wet and dry steam.)
StmEng_hpt Enthalpy as a function of pressure and temperature. (For saturated and super heated steam.)
StmEng_hptl Liquid enthalpy as a function of pressure and temperature. (For water.)
StmEng_hps Enthalpy as a function of pressure and entropy. (For wet and dry steam.)
StmEng_spt Entropy as a function of pressure and temperature. (For saturated and super heated steam.)
StmEng_sptl Liquid entropy as a function of pressure and temperature. (For water.)
StmEng_sph Entropy as a function of pressure and enthalpy. (For wet and dry steam.)
StmEng_tph Temperature as a function of enthalpy and pressure. (For wet and dry steam.)
StmEng_tps Temperature as a function of entropy and pressure. (For wet and dry steam.)
StmEng_xph Steam quality (vapor fraction) as a function of enthalpy and pressure. (For wet steam.)
StmEng_xps Steam quality (vapor fraction) as a function of entropy and pressure. (For wet steam.)
StmEng_hpx Enthalpy as a function of pressure and steam quality. (For wet steam.)
StmEng_spx Entropy as a function of pressure and steam quality. (For wet steam.)
Parents
  • イシカワさん、
    PI System Explorer User Guide(日)がOSIsoftのテクニカルサポートからのダウンロードも可能です。
    2015のがありますが、2012 R2のバージョンの日本語版がありません。
    2012から2015にスチームの関数は特に変わっていないと思うので、2015のバージョンでも参考になると思います。
    PI System Explore 2015 User Guide:
    https://techsupport.osisoft.com/Downloads/File/232091ab-1949-4d26-965f-5c8d6ddd7976
  • Jeromeさん
    ありがとうございます。
    ダウンロードも出来ました。
    PI System Explorerでのスチーム関数は ProcesBookでは使えないのでしょうか?
    例えば、
    StmEng_tsatp は使えますが、 Steam_TsatP はつかえない。
    PI System Explorerユーザーガイドでは、
    このスチーム関数を、PI Performance Equation で使用する同様のスチーム関数と混同
    しないでください。PI Performance Equation で使用するスチーム関数の名前は
    「StmSI_」または「StmEng_」で始まります。分析式で使用するスチーム関数の名前は
    「Steam_」で始まります。
    と記載がありますが、PI Performance Equation とは何ですか?
  • PI ProcessBookで利用したい場合は、下記のようにできます。
    (下記の手順でAF 2017で実装しましたが、2012のバージョンでも動くと思います)
    1.AFでスチームの関数を利用する式を書き、属性に書き込んでいます。
    2. 属性の定義は下記のようにします。Data Reference: None, UOM: J/(g K)
    3. PI ProcessBookで値のシンボルを選んで、タグ検索ではなく、AF2のオプションを選んで、上記の属性を検索します。
    4.結果
    PI ProcessBookのData Setでもスチームの関数を利用できますが、
    現在では、ディスプレイに分析、しきい値、他のロジックは入れないのうがよいと考えられます。
    その変わりに、このデータのすべてをAFでしっかり管理したほうがよいということです。
    PI Performance EquationはAF分析の前のストリーミングアナリティクスの仕組みです。
    現在はAF分析のご利用をおすすめ致します。
Reply
    4.結果
Children
